Hi all, For the last year i'v'e been renting a shed with 240v. Max supply currently is 20 amp although I run a 240v Mig and Arc welder on 16amp plugs and cable.
I do have three phase motors, compressors and mill which I can't run at present. However i'm going to run a 30meter 415v supply from a nearby power house (each phase has a 60 amp fuse and an earth). I've recntly bought quite a fwe Larger mig and Tig welders at auction but all these have 5 pin plugs and therefore an additional neutral core.
I will be getting 32AMP armoured cable 4mm core for this extension and onl running once device ant any one time. However can I run the five pin welders when I only have a four core supply and no Neutral? Can I make an adaptor which put the nutral of the welder to the earth also?
Cheers Rich
Cheers Rich
unfortunantely, the way you've written the explanation even confused me!
