Circumference is... Pi x Diameter
to get the circumference multiply it by three (well 3.142)
I usually go over by about 10-15% and trim the ends off.
So that would be Pi x 250 then wyn...
Yes diameter x3.
I was very doubtful when a stage building mate of mine told me.
Pi R squared + area
2Pi r = circumference or Pi D
I think,
I had to test it with a piece of string.
Simple. or I am stupid.
No, if you are after a 500mm diameter ring it's Pi x 500 =1571mm long you would need to cut and then roll it into a ring.
Whats the ring from..... you need to work on the mid line of the material for rolling really....
If i wanted to roll a 1000mm OD ring from 20sq,
you need pi x 980
If you have a pi button, use it, on big numbers it can make a few mm difference.....if not, 3.142 would do.
Then I normally would take a couple of mm off to allow for where the edges might not quite come perfect, and a gap for welding....
Id cut it about 3077
Why is your wife in prison?
This is where I get annoyed with my wife, as in engineering terms when we talk of O/D we mean actually mean the total circumference, but we just naturally call it the O/D, now the figue you have just given me is what I came up with first, but she (being a maths teacher) in a prison mind, swore blind I was wrong, I'm glad you have affirmed my sanity.....![]()
I use this example, which helps my laddies understand.....
Where have I seen that before,glad its of use.
Yes I did it a couple of years ago when the same question was asked
http://www.mig-welding.co.uk/forum/showthread.php?t=16795&highlight=diameter
This any use to you?, shows how to use the mean Dia to develop bend lengths,
