Tupers
So it would seem everyone else's projects have been moving along but mine has barely been treading water. This is mostly because I've been busy with restoration work a '63 Mini convertible but I've also found my self falling in and out of love with the estate.
I decided the best way of raising my interest again was to buy something shinny for the car. I had originally planned to stick with the standard brake and clutch MC's but got a good deal on a Wilwood set-up and seized to chance to clean the engine bay up a little more.
Now for the second part of my madness.
First thing's first I **** the cross member braces, they're ugly and I can make something nicer so they're gone.
Then there's this.
Although from a distance the smoothed off bulkhead looked ok I still wasn't happy.
The most logical thing to do (in my head at least) was to chop it out and make a new one piece bulkhead. I started by drilling out the spot welds along the bottom of the windscreen frame and slitting either end of the scuttle.
Then came more chopping.
I've retained the hinge perches and the new steel will the butt welded in around here once it's all tidied up.
I also removed the bottom dash rail as it will be covered by the dash board I have planned and I can add something more suitable for my new pedal box and steering column set-up to mount to.
Then there's this.
) about keeping the engine bay simple and clean I decided to get rid of the dip in the centre of the front crossmember. It was there to clear the bottom of a carb but seen as I'll be on a throttle body I don't need it.
