Doug_B_928
New Member
Hi folks,
I'm a new member. I didn't know there was a forum just for MIG welding; very cool. I'm new to welding. I'm planning to restore an old car myself (I'm new to this too). I purchased a Lincoln 180 Dual before Christmas. I've been doing some practicing (using 75/25 gas). I understand that for thin sheet metal the technique is to tack the pieces together, then do a series of spot welds. I was under the impression that, to fill in the seems once tacked, one should keep the individual spot welds sporadic to avoid heat build up. I watched the tutorial video on this site and it shows doing a series of spot welds in a 10mm row. Would limiting it to 10-20mm be enough not to heat the panel such that it warps? If the preferred method is to jump around with the spot welds, then what is the technique for putting a spot next to a cold spot. Do you start on the seam and then move back to the spot, or vice-versa, or ?? Wouldn't a really cold spot need some extra heat to get penetration compared to the sheet seam next to it?
Also, I read about some .023 wire that is easy to grind (don't recall the exact name). The local welding shop told me that .025 (Lincoln made in Canada) is just as good for sheet as .023 (I had been practicing with .030). Is the easy grind chemically different, or is it just because it's .023 that it's easy to grind.
My first project has been to refurbish an old muffler. I did it with .030 and poor technique. The metal was extra thin (33 year old muffler) and the new metal was 22G, so lots of fun with blow through and chicken feces.
