Ok, first of all, I have never done Mig welding before, always used a stick welder so, keep that in mind as you rip me apart
The Rhyas Turbo Mig Welder 30 to 135 amp gas/no gas looks like all the other bottom of the range migs I have looked at in store and online. For £142.99 you get the welder, one reel of .8mm gas wire and one smaller reel of.9 gasless wire. Fitting and setting up is a total doddle, just remember to observe the polarity changes when going from gasless to gas welding. I had the .9mm gasless wire in and the power at the second last setting and the wire speed at half way.
When i first tried to do a run, nothing happened, the wire touched the steel, nothing..............After a few minutes head scratching and nose picking I realised it was NOT a stick welder which is live ALL the time and that I would have to do some extra work like squeeze the bloody trigger!!!
First attempts were like a left handed chimp, second attempts had me getting closer to the metal and increasing the wire feed to full just to get a quarter decent run. The spots I did came out quite good. The splatter is amazing to say the least as is the blue smoke bomb that goes off everytime you use the thing! I wonder if that spray on anti splatter you use for stick welding would work here?? Anyway, the machine works well at the settings I had it on. Looking forwards to getting a small argon mix bottle and trying it gasless. Now to try and upload some piccies for you all to cry over
I angle ground it even though it was a brand new bit delivered this morning. All the crud is from the smoke and splatter. Infact, look carefully at the spots image, you can see the earth clamp wich is also brand new clamped to clean metal
Does it honestly come flat packed? I want it even more now!
