brewdexta
The biggest tool in the box
- UK
I've got a handle to weld on a casting that has been snapped off and a crack in the base of a power hacksaw frame
Reading around the subject, either brazing or austentic SS wire is the way to go, See as the handle will get some loading then I was going to drill the casting then weld around it. I was thinking of making the handle out of a piece of SS rod about 15mm diameter with a spigot to fit in the hole. The crack in the base I was just going to make a v- groove and slowly fill it with SS.
So which particular grade of SS wire? it needs to be 3xx grade to be austentic, 308 or 316?
Next question, the little 0.7kg spools, will they fit in a portamig? I can get a 5Kg in with the adapter but will they take the little spool or do I need to rig something up temporary - I don't warrant buying a 5kg reel for the amount of SS I do currently but open to suggestions.
Cheers
Andy
Cheers
Andy
