Hi
I read with interest about the Astra Norm was having problems with and having an 09 Astra which is useless it does not surprise me.
But I digress. I have a 1.9TDI passat estate that had an issue with a turbo to intercooler pipe splitting. It seems to have more than one problem. Which is why its hard to diagnose. BUT its had a new MAP sensor. )before I found the spit pipe) . since I fitted a new turbo pipe it ticked over like a dog. It also ran awful and seemed to vibrate/osolate up the gear stick rumbling/roaring in the engine bay.
WE took the EGR vaccum pipe off the EGR and it ticks over fine. But still has the "vibrate/osolate up the gear stick rumbling/roaring" but less apparent.....>> MMMMmmm hard to describe the symptoms you see.
When its cold if you push it much it drops into limp mode and no power. If you go on a long run it does this a few times for the first 10 miles and then seems to stop playing up and runs OK. No right but drivable.
I have disconnected MAF and tried it and its no better and drastically down on power.
Its getting annoying now as it shows NOTHING on the diagnostic computers we have tried.
Any suggestions appreciated.
Regards Andy T
Regards Andy T
she says the car will have a good run to Wiltshire,
