Jim_gsxr1000
Mechanical Magician
Bought 0.8mm Flexovit Ultra Thin Metal Cutting Discs a couple of days ago for using on my wood burner project
Best cutting disks i have ever used cut very clean, fast and they last
You get 5 in a pack from screwfix and are £8.50
i cut the handle off my wood burner, put 3 cuts on the door (the hinge cut was done with a 1.0mm to give a wee bit extra clearance) and cut the top and bottoms off 2 disposable argon cylnders and the disk has only lost about 1/8" of the radius or 1/4" of the diamiter.
They dont skip or jump atall when starting a cut and they are very easy to keep in a straight line
Top product, would definatly recomend them
i cut the handle off my wood burner, put 3 cuts on the door (the hinge cut was done with a 1.0mm to give a wee bit extra clearance) and cut the top and bottoms off 2 disposable argon cylnders and the disk has only lost about 1/8" of the radius or 1/4" of the diamiter.They dont skip or jump atall when starting a cut and they are very easy to keep in a straight line
exit disc after little use.
