SiPMerlin150
- Sunshine Coast, Queensland
Hi everyone, just finished converting my MIG over from gasless to now use gas. I've dabbled with gasless wire for a while now at home, and use gas MIG at work. I love the minimal cleanup and better looking weld beads.
I initially purchased a 600gm disposable CO2 cylinder and regulator (BOO! I know,
) I'll be opening up a BOC account and get a 2ltr cylinder of argo shield and a regulator from the stockroom in work to fit onto the BOC bottle.
I've uprated the gas hose fron the 2mm stuff found in hobby MIGs and used a 6mm hose, for better gas flow, routed the hose through two drilled holes in the welder unit case and up through the inner sleeve of the torch cable to the valve block in the trigger assembly. All joints are sealed gas tight, no leaks.
I need to swap the polarity around inside to torch positive and finally I need to get some 0.6 or 0.8mm solid wire, as all I have lying around is Murex 1mm and even though the mig will feed and use it, You can just tell it isn't happy burning it.
Heres a pick of the result. As the weld progresses you can see as the gas bleeds in the weld bead begins to form as the gas forms a sheild.
Again, its a 130 amp MIG on the wrong polarity with 1mm wire and CO2
