Looks like the old Danfoss pressure switch which just cuts out & then back in at the pressures you set it to, mine drove a contactor so no real amperage involved,the downside is it doesn,t unload the pressure when stopping so your compressor's starting up under a load,depending on what it's set to,I replaced mine with one off ebay[cheap as chips] about £12.00 & when it cuts out you hear it hiss as it unloads the pressure in the supply pipe ready to re-start without load.
slan go fol
fit the new pressure switch in place of the old one and conect the small pipe between the compressor outlet pipe and tank one way valve to the tank .tee it in u can still use the original starter as it has the overloads in it for the motor .wire a live and neutral feed from its output terminals to the pressure switch input and wire a feed out to the motor . if your not bothered about having overload trips fitted wire a feed direct to the pressure switch and out to the motor and use the knob on top to turn it on and offso if i fitted that would i then do away with the pressure switch and the big box with the start and stop buttons on it as that has one on it
thanks
no hiss when it cuts out
could you tell me what to look for on ebay as im not really sure
could i just type in pressure switch or will the bring up non unloading ones
thanks
new motors struggle so il have to change iti think as eil put in his post have u a non return valve on it from pump pipe to tank id doesnt look like u have. u will need one . are u handy making things to alter it. a bit of pipework and a few fittings ectthanks for the replies
ill order one of those and get it wired in asap then
thanks
