blacksmithstris
A few years ago I bought this for £5, I thought what a bargain! I used it a little bit at first, then it sort of fell by the wayside as it has a broken bit of the vice that holds the steel for cutting. I don't normally cut bigger stuff, I mainly work with thin bar (6-16mm) so I've just got into the habit of using my grinder with cutting disc to cut stuff as I don't usually need accurate cuts. However, I decided to dig it out last week as I needed to cut up some really big angle as I'm making a stand for my Post Vice and Swage Block. Still works fine, if a little slow which could be down to the blade being dull, the motor is really rattly though, and as you can see it generally is in a sorry state, needs a good clean...
I am wondering how, if at all I might be able to fix the broken bit, I've attached a pic. It's broken off right through the threaded hole. I don't have the part that has broken off. Perhaps I might be able to find a replacement if someone has one of these that doesn't work anymore? Where would be a good place to advertise for something like that?
Also, the tray that catches the waste "metal dust" for want of a better word is completely full and has fused into a big solid lump. (It was like that when I got it) I've tried chiseling it out and managed to get the top layers off, but it gets more stubborn at it gets further down, anyone have any suggestions how to get rid of this, I've soaked it in oil, that helped a bit, or is it just down to elbow grease and a bigger chisel??
There is also a pot with a rod in it full of "gunk", I'm guessing it might be a kind of damper? what should it be filled with?
Anything else I should be aware of? I'm not experienced at taking machines apart, just operating them, I'll just excuse myself now if I don't explain myself well, use the wrong terminology or say something that doesn't make sense!! Pictures aren't the best, I don't have very good lighting in my workshop.
Thanks in advance for any advice you might be able to give!
