I've never seen a 6013 that ran DC only. In the old days that would have been a (now extinct) 6012!
You will visit the bench grinder many times the first week sharpening tungstens,![]()
Do both ends half's the walking or even better get a spare tungsten save 3/4 of the walking!
Tig you push button to start a weld via hf. Then it just a matter of keeping the wire and travel speed smooth without contaminating the tungsten or getting carried away.
Yea it's fas basic
Haha the walk of shame to the grinder! been there, done that
Jim
It must be a open circuit voltage issue then, most likely as those same rods sputter out repeatedly on my home unit, behaving just like trying to burn lo-hi's on a buzzbox..
Though they are a cheap should I dare say 'just about does the task when run right' type of rod. They are with no doubt imported junk...
I sneaked in a dozen of my Esabs into the college today and burned those instead. I can't see that being classed as cheating, as the aim of the course is to produce consistant welds. You dont want cheapo rods hindering what progress you are making.![]()
Can the instructor demonstrate the welds using those rods? If he can't they shouldn't be using them.
no doubt they are cheapos though.
all the paperwork is out of the way, and I'll be going for a B.S. 4872 in MMA, in mild steel thickness ranging from 3mm - 12mm in flat PA position, PB flat/vertical. Possibly go for the vertical up, down and have all positions covered. Its only £300 You would be doing 'stoving' for vertical down, usually only on pipe butts with CEL electrodes. Not something they generally teach in college![]()
That'll be the difference then. A 'proper' place
What's it called?
Oh yeah I know it. At Wilkinson Star. Nice one.
Done everything today, tommorow is destructive testingall the paperwork is out of the way, and I'll be going for a B.S. 4872 in MMA, in mild steel thickness ranging from 3mm - 12mm in flat PA position, PB flat/vertical. Possibly go for the vertical up, down and have all positions covered. Its only £300
