visor_down
- UK
http://www.sgs-engineering.com/hydraulic-jacks/axle-stands
Evening
Looking for set of axle stands and thought I would ask for thoughts on the above range. All are similar price so looking for most stable and easiest to use.
Will be used on a gravel drive (not the fine chipping sort) so needs to be stable.
Not sure which saddle type is best the cast v type or the bent metal plate? Same for the tripod vs 4legs
Will be used on all sorts from focus which is very low through to 4x4 so hoping can get one that does it all. Was going to get the largest to cover all bases but unsure if the 370 min height would be inconvenient on standard cars.
Any thoughts or experiences on which are the best buy would be appreciated
There look to be pretty good value and ce tuv approved but open to other suggestions
Cheers
Evening
Cheers
