Barnabas
Sorry about this really simple question.
I had the electrics installed in my shed before thinking about welding and thus didn't specify anything special.
An armoured cable was taken from the fuse box about 5 metres away and feeds an ordinary 13 amp domestic socket in the shed. I have been running a 140A arc welder from it with no problems but only use short runs and haven't really put it to much of a test.
Having read all the advice on this excellent forum I have decided to buy a Portamig 181 from Weldequip (but he doesn't know this yet). I guess this can run at near max power off the domestic supply but would I be better off having a 16A socket? If so how do I tell what the existing wiring can cope with. It looks like a chunky bit of wire and the fuse wire holder has a yellow dot on it.
Finally - at what stage should you think about having 3 phase and what is involved to have it fitted?
Any advice appreciated.
I don't tend to weld thick things, though have run the welder on max power, but not for a long duration.
and having had some reassurance from Steve will stick with the existing 13A setup and see how it goes.
