Needs to measure from 1ohm or less.
For that sort of work I'd get a cheap and cheerful one from the likes of Maplin.
Really? Less than 1Ohm? That's getting down to laboratory spec. Do you mean to test for poor earth connections and the like? You will need a good quality multimeter for consistent readings, I wonder if a cheapy from Maplin will do? Fluke 233A or similar from AVO (which I own) might be better, BUT..
I've found lots of bad automotive earth connections over the past 30+ years, very few by using a meter. Most by using my eyes though.
You said you wanted a good one! I just use a normal fluke or RS meter for my use as that's what I have at work but simple stuff really on landrovers
I also check voltage drop across doubtful connections when fault finding rather than using resistance measurement with the cheap meter I use.
I got one of these http://www.ebay.co.uk/itm/AC-DC-Pro...iagnostic_Tools_Equipment&hash=item3a76405c3e
I don't know if it has what you require
