- Birmingham
you can get good quality plugs that dont shatted when dropped and you can always solder the ends of the cable
You can't guarantee a good permanent mechanical connection with screw terminals onto a soldered wire.
christ where do u draw the lineYou can't guarantee a good permanent mechanical connection with screw terminals onto a soldered wire.
talk about the far end of a fart and where it comes from
just twist the ends up and put em in
christ where do u draw the linetalk about the far end of a fart and where it comes from
2.5mm cable will fit in a 13 amp plug no bother with the ends twisted so no strands will be sticking out .the point is that the terminals in a plug top arent always the same size.
some are bigger than others.if someone cant fit all the strands in,knowingly or unknowingly,they are taking away the benefits of bigger core cable
and if your eyesights that bad and your incompetent dont bother4mm solid core will fit in most.that wasnt the point.
also a sealed plug is a hell of a lot safer than a serviceable one
crimped without ferrules,with heat/compression,will reduce the diameterthen what is ?
as far as i know you cant buy ready made leads with a Ridiculously thick cable squeezed into a moulded plug anyway and a crimp only adds to the diameter of the cable
Not always the case, there are a number of very dodgy sealed plugs that don't meet british standards.
http://www.esc.org.uk/public/guides-and-advice/checking-a-plug/testing-sub-standard-plugs/
You can regularly check the connections of a traditional plug, the sealed ones offer you no way of checking them and the first you know of a fault is when it over heats, melts or worse case sets on fire.
only upto a point that it becomes as tight as a solid core, but that still doesnt alter the fact they dont use cable that cant fit into a standard 13 amp plug should the need arise to replace the moulded plug
the point was there are people who will make a hash of the connections,at both ends of the lead.
this is true but it wont stop them making the lead up because people like that think they have done a good job and dont accept that their work is below standard
we agree on that at least
well it would be boring if we agreed on everything wouldnt it ?![]()
This is the recommended solution for outdoor trailing cables.
Larger cable will have less voltage drop over a given length. What length do you need?
I've a few of these kicking around, I know it's probably not the cheapest way of doing it, but it was quick and easy at the time. I've got home made 13A/16A adapters for each end.
http://www.screwfix.com/p/ced-240v-extension-lead-blue-2-5mm-x-14m/23418
