BoatBuilderDave
- Ireland
Doesn't mean that gluing is better/ stronger than welding. Just means that on this case the roll cage met the standards and the chap had no problems.
Likewise Lotus versus Renault which is not a fair comparison as Lotus have been making composite and fibreglass cars with gluing for years. I still don't accept that a glue joint can be better, stronger than a welded joint.
You can easily make a well designed adhesive joint which will not break before the metal. At that point it no longer matters how strong it is.
From then on you only care about longevity.
A weld introduces a Heat Affected Zone around the weld. So while the weld may be strong, the metal around is is weakened somewhat. Adhesives do not introduce any such HAZ.
It's unlikely that an adhesive based butt joint would be anywhere near as strong as a welded butt joint, but then, who would create such a joint?
A welded lap may be weaker than a glued lap due to the HAZ. Particularly for thin metal.
Most of what I know about glues is from building wooden boats, but the principles remain the same.
I still don't think it's going to replace welding wholesale, but as has been pointed out, it's been used in aircraft for a long time - thin sheets, easy to have lap joints in the design. No distortion from heating.
Horses for courses.
it would be the same with high rise flats and towers made of steel
