Hi Guys, anyone up on pressure washers? used mine today for some serious patio / driveway cleaning before the winter sets in, it ran fine for about an hour then stopped with a loud buzzing sound coming from the motor and no pressure from the Lance, I left it for ten minutes or so and it started again but made the same buzzing sound then stopped. Figuring It was dead and with nothing to lose I stripped it down expecting to find the head of the pump cracked or the valves or pistons or whatever there called damaged, but everything seems fine, nothing broken and all turning and moving as they should, the head seems fine with no cracks evident the only problem I could find was the electric motor itself, the casing was seriously hot even an hour after it stopped, yet it spins freely, the fan is attached and it ran when i switched it on without the pump part attached. I plan to re assemble it tomorrow if I can remember where all the bits go
and see what happens, any ideas why it would overheat It's a cheap machine but has given good service and has ran longer than an hour previously with no issues. Thanks in advance Norm
