Polished
New Member
Hi folks just a tip that worked for me that might help others. I'm in the process of making steel doors for my 'Man Cave' :-). all door frames made and I've begun sheet with 2mm 8x4 steel sheet which of course is covered in mill scale. Cleaned off edges whilst welding with flap disks but way too expensive to go over the entire sheet to remove the scale before priming and painting. The answer when looking around the interweb was Muratic acid more comminly know as hydrochloric acid.
Quick trip to my local builders providers and looked around came across 'Boss Cement and Grout Cleaner' 20% Hydrochloic acid - perfect ! :-)
As with any acid of any concentration , safety is a must, full face visor, Long Rubber gaunlet gloves, plastic apron if available but certainly no uncovered skin.
Never add water to acid to dilute , add acid to water - read instructions !
Painted it on with brush, had a few rough bits so used a pot scourer and left for 5-10 mins, ran the pot scourer over a few more times and flushed (from a distance) with lots of water from the garden hose
heres the result, had to run the wire brush over one or 2 spots but it fell off.
Anyone who has tackled with this in the past will know what a PITA it is.
Hope this helps.
Hope this helps.
