SiPMerlin150
- Sunshine Coast, Queensland
Hello, I'm mainly on the arc welders section as my first found skill was with stick welding. I'm familiar with MOT repair work from the garage I work within, Seam welds where needed/plug welds as needed etc. I've half done a job to a large rusty mercedes sprinter, rotten in a few places on the sills.
The mig is an old (10+) beasty lincoln compact 185 (old school!)
and set on the minimum Voltage setting will readily blow through 1.6mm body steel.
I used a stitch welding technique to create a seam weld, alternating areas of welding to keep warpage and burn through limited...
Its not pretty, its half done also, plus i'll be going over areas that I find unsatisfactory tommorow.
Heres my work...dont laugh!
P.S. the snotty looking bits at the sill lip aren't mine and will be grinded off tommorow!
and set on the minimum Voltage setting will readily blow through 1.6mm body steel.I used a stitch welding technique to create a seam weld, alternating areas of welding to keep warpage and burn through limited...
Yes, well I ought to take in my Buzzbox and see if they can do anymore than stick the rod to the work piece and make the buzzbox make angry sounding noises!
