Hi all,
I'm in the process of fabricating a different kind of scooter engine stand to those I normally make. Part of the job requires a very square cut on a piece of 50mm x 25mm box - about 250mm long - as it will be stood on it's end.
If it was a smaller size, or better shape I'd stick it in the lathe and face it off, and I don't have access to a milling machine.
I'll be cutting it with an evolution rage saw, which will give a good cut, good enough for welding together, but not a perfect cut.
I also have a linisher, which is great for tidying up ends, but again a perfect cut end would be achieved more by luck than planning as the angle table tends to flex.
Any other ideas?
Is there a way of doing this with a tool mounted in the lathe chuck and solid mounting the workpiece on the cross slide?
Cheers
Jim
Any other ideas?
Cheers
Jim
