SirDick Diodenob esquire
Its a 1965 model and probably on its last legs , need some advice how to get it started . Its not been used for a while and when I went to crank it over it was stuck solid so spent an hour inching it with the starter motor but now its turning over ok but still not firing up . Its a 3 cylinder diesel with cav injection pump , diesel looks ok with no water in it , drained both filters and bled them and bled the pump , also disconnected the injector pipes and turned it over , the pump is getting deisel into the injectors . Used easy start , its trying to start and loads of black smoke but dies as soon as I let go the starter . Dont know what to try next but need to get it going tomorrow somehow . Was thinking about removing the injectors and giving them a clean . I know the compression is probably well down but its been like that for years and still started with easystart , any ideas on what else to try ? Bump starting is not an option as its a digger with back hoe and shovel on the front and unstable at anything faster than about 3mph .
