evening all
i'm currently de-activating a shotgun (i'm fully covered licensing wise before anybody asks) for those in the know its an over and under, for those not it means one barrel is on top of the other
heres my problem, for them to be deactivated they have to have both barrels blocked with plugs and the plugs welded along the length and around the top of the plug in the chamber (top photo shows the plug in the top barrel) now when i've done side by side shotguns they have been no problem as because they are side by side access is not a problem, but on the over and under i cant get the torch into the top barrel.
the second picture shows the idea that i have, extending the tungsten to reach, up the gas flow and block the barrels to help keep the gas in the weld area. but i'm not even sure if this would work?
i'd appreiciate any advice any body has on doing this as i'm sure someone will have come accross something similiar before, i dont really want to be spending loads on new bits of kit like a torch with flexible head or something like that as i'll only be doing this sort of thing every now and then
tom
tom
