What should i do? Is etch the best way forward?
thanks
andy
What are you doing ??? Etch has differing qualities to epoxy.
Grinding rust from underneath my 4x4, trying to stop it from coming back.
yeah etch would be more suited to clean new steel , epoxy really will be far better at what you want to do
have you looked on ebay at the jotun , maybe split a tin with a mate or something ?
could work out reasonble anyway as you wont have to do further top coats if you dont want to
Does the 2pack epoxy need an air fed mask and how tough is this paint ? I might use it on a motorcycle frame as an alternative to powdercoating , would it be good for that ?
It's very tough and very chip resistant when cured, yes it needs air fed mask but you don't have to spray it.
Powder coat is good but once it's chipped rust will creep behind it.
The powdercoating over here is very poorly done and i won't be using it again , can this primer be rollered on ?
yes spot on ..brush or roller it then the chassis black before the epoxy has fully cured , it will all bind together then
