steveo3002
what about a farmer ..should have something that will stand on the cambered road and lift it for some beers
Rope can be your friend. Secure the engine hoist from tipping outwards by tying it off to something suitable inside the house, raise the stove, then push or pull the hoist into the house. I use small bits of angle iron to chock hoist casters. Works very well.I was thinking of wheeling the engine hoist out on to the balcony, with the jib at full extension, attaching a block and tackle to the hoist and pulling the stove up like that. But I had visions of hoist, block, tackle and stove all crashing to earth with a very expensive crash...
Once you solve the "raising heavy stuff to the second floor" problem you can do the same again in future. Handy for furniture, fat girls, whatever...
As the thread title indicates, I have a small quandary; well, a quandary that weighs around 200kg to be precise....
I'm planning on installing a woodburning boiler stove in my gaff in the South of France. The living room (where the stove is going) is on the first floor, with a garage directly underneath. There are two possible access routes to the first floor - the staircase from the ground floor or the balcony on the first floor, leading to the living room via a sliding French window. The balcony is about 2.5m wide by about 1.5m deep.
I can unload the woodburning stove from my van using an engine hoist, which can also be used to lift the stove into place on the plinth in the living room that the previous occupier had thoughtfully provided. But the big problem is getting the stove from the ground floor to the first floor.
Is this just a case of organising half a dozen burly chaps and mauling the stove up the stairs (it will be delivered palleted, for convenience sake), or is there an easier, smarter way to do this? The stairs are spacious enough to do this, but the idea of 200kg sliding back down towards the poor ******s at the back end of the lifting action doesn't really inspire me with confidence.
I had thought of hiring a forklift to lift the stove up to the first floor balcony, but the road outside is steeply cambered side to side and the house is also on a steep incline, which would make using a forklift a tad precarious.
I'm also at a loss to think of anywhere solid enough that I could attach a block and tackle to. I suppose some kind of crane hire is a possibility, but finding somewhere to get that from in rural France (along with the language difficulty) could be interesting.
Any ideas (off the wall or otherwise) gratefully accepted...
cheating....
some 1" thick wooden blocks and some bricks amd you can walk it up the stairs
After you, Claude... Frankly, I doubt it. On its two (!) pallets the whole plot stood 1.7 metres tall and was decidedly top heavy. Shipping weight was 250kg, or so it said on the manifest.
I'm not saying Man with Manitou was the only possible way to do it, just that it was painless, reasonably straightforward and nobody got hurt, died or had things fall on them. I'll take that any day.
