- UK
Al
... Come across Liquid Metal Assisted Cracking (LMAC) mentioned in a spec for an upcoming job. Not heard of it before, so found a bit of simple text on it...
If steel is subject to tension, or shear stress, and if various hot liquid metals (zinc, lead) are in contact with it, and if they can enter into the surface of the steel, the liquid metal can infiltrate into the steel at a molecular level. Having molten zinc atoms between grains of the steel reduces the tensile strength to zero at that location.
If the stresses in the steel are high, a crack can form. If this crack reduces the stress, the minute crack can stop at birth, but if the crack results in an increase in stress at the tip of the crack, the size of the crack will extend. In effect, the zinc or lead can be a knife so sharp that it is one atom wide at its edge. Unlike a knife through butter, the liquid metal "knife" does not need pressure to cut: what it does need is tension in the steel; and an engine to maintain the tension in the steel by continuing to pull the faces of the cut apart, allowing the liquid metal to penetrate. When the tension disappears, the crack stops. While sufficient tension remains, the knife slices in. A crack 3/4 of the depth of a section can form in a second.
In the spec i have, it seems to be linked with galvanising. From what i understand, for it to happen, it would be inherent stresses within the metal from fabrication/rolling/shearing etc that crack when subjected to galvanising rather than cracking in service. Is this correct?
... Come across Liquid Metal Assisted Cracking (LMAC) mentioned in a spec for an upcoming job. Not heard of it before, so found a bit of simple text on it...If steel is subject to tension, or shear stress, and if various hot liquid metals (zinc, lead) are in contact with it, and if they can enter into the surface of the steel, the liquid metal can infiltrate into the steel at a molecular level. Having molten zinc atoms between grains of the steel reduces the tensile strength to zero at that location.
