The Buddah
I'm using phone for internet.
Hello,
I need a stiff finger to point me in the right direction because below is what i THINK is the way things should go but i'm not 100% sure.
I'll be trying to weld an inner sill to a 4mm box section for the floor project on the disco soon. I was going to run a bead along a 4mm section to check for penetration. Once i feel happy with that i intend to weld the 1mm to the 4mm by running a seam using a eeee motion if that makes sense so that the weld pool spills over onto the 1mm section. I'm considering welding two inch sections at a time alternating from one end to the other until they meet in the middle.
Would i be correct in welding this way?
Thank you.
Thank you.
