GrahamGKD
Hi Folks,
I've been trying to TIG some fine stainless steel mesh (20 holes per linear inch; wires are 0.35mm in diameter; apertures are 0.92mm) to some 3mm 304L rod, the purpose being to provide a kind of translucent skin to metal sculpture insect wings. The rod forms the perimeter of the wing. I quickly found that welding from the top was a complete non-starter as the mesh burned back instantly, so I tried wrapping the mesh around the rod and then welding from the underside. This worked after a fashion but I was right on the threshold of melting the rod (the rod drooping and loosing its form) before getting the wire to fuse. Also, the rod was getting quite grey with oxidization (too much heat?). I was working with the wing laid mesh down on a copper plate.
I also found that, where the wire did not fuse on the first run, it was (for me in any case) not possible to go back and repair the non-fused section, meaning that any faulty section in my wing meant writing off the whole thing. I fiddled with all kinds of settings (I'm no TIG expert) but in the end I was running my Lorch with a 1mm tungsten, about 7 lpm, 35A/12A pulse at 2.2 Hz. In the end I gave up and simply fitted the mesh by wrapping around the rod with a pliers - this works better than you would think; saves all kinds of costs in gas, power etc. but does seem like a bit of a cheat and has the disadvantage that it is hard to get rid of all of the sharp ends of wire.
Looking back at my ebay purchase, I don't seem to have a spec for the mesh - maybe it's not a suitable welding grade of stainless - I will try to find out.
My questions is - for those who have had the tenacity to read this far (Thanks) - should I be able to weld this, or am I asking too much of myself? If I should be able to do it, where should I focus my next experimental session?
I will be away from the forum for a while so if I don't respond to questions or suggestions please don't interpret this as rudeness.
Cheers,
Cheers,
No, seriously, I like that suggestion, I might just do that - thanks.
