Paul The Pie Eater
Hi all, has anyone ever made a shot blaster from a butane/propane gas cylinder? I am thinking of making one but I am unsure on how they are plumbed internally. Before anyone shouts "Health & Safety!". I know how to make the bottle safe. I will open the valve to drain the gas, (nearly empty anyway). Then remove the valve and fill with cold water to remove all the gas before I start fabricating. What I would like to know, is how the blast medium is fed from the cylinder to the nozzle and if the cylinder is permanently pressurised.
Many thanks, Paul.
Many thanks, Paul.
that clears that up
, But ive got a couple of questions, Im going to use a hydrovane ( towable type) compressor borrowed off a builder friend so pressure isnt a problem, My gas bottle had a 3/4bspt so ive used 3/4 fittings, Can i use the yellow hose that are used with these type of compressors for the breaker guns etc for a blast hose (3/4 inside dia), im building the pot to blast the underside of my campervan currently laying on its side on the drive
, so what size nozzle should i be using and any idea where i can get the holder and nozzles from ?. will a water filter that ive got plumbed in for spraying/ air tools ( similar to the one on your pot ) be man enough for this type of compressor ? ive used this type of compressor on building sites and the moisture that comes out the guns is horrendous !! Dave
