JimM
Hi Guys
I've built a hub puller similar to the one shown here
http://members.visi.net/~kohout/hubpull.html
The puller is bolted to the hub and then the screw tightened which pushes against the central shaft and leverage separates the two parts.
The first hub came apart no problem but the second one is proving to be a right bugger (This is a notorious problem with Spitfire hubs) In the end the threads on the nut/bolt gave out. I'm going to rebuild it but will a UNF or UNC thread work better in this application ?
Cheers
Jim
Cheers
Jim
