SiPMerlin150
- Sunshine Coast, Queensland
Do i have my amps set too high?
2.5mm 6013 rods, when i do full runs where i'm using a full rod, i've noticed the whole rod is heating up and glowing like a heater element!
I can tell when this happens as the you can see the rod being vaporised and it can sometimes burn away 1 inch per second!
I have the settings on the welding box set in the lower range of what a 2.5mm rod would be ran on, and the slag peels off the welds easiy too.
( i am skeptical at the power settings accuracy on the unit as its a cheap screw in/out power selector with a small arrow in a viewing window).
I can tell when this happens as the you can see the rod being vaporised and it can sometimes burn away 1 inch per second! I have the settings on the welding box set in the lower range of what a 2.5mm rod would be ran on, and the slag peels off the welds easiy too.
,,,, one learner trying to share what works for him to another..
Weldequip sells them on here in 5kg boxes, but i doubt it you'd eat through a box, unless you're welding for a few hours each evening.
