stewart.d.campbell
Hi everyone, i have bought a 200l compressor that needs a few bits and need to check what bits these are so if anyone can help that would be great.The compressor is a 200l sip airmate 5.5 hp 3 phase that has had the 5.5hp motor swapped for a 3hp single phase motor so as it needs a pressure switch would i be best to get the switch for the 3hp single phase sip and looking at the pictures is it just a pressure switch i need other than it also needing a air filter cartridge and filter.Am i right in thinking that to wire it would be plug to pressure switch then pressure switch to motor, and lastly does the gearing ratio from the motor to the pump look about right for this motor, thanks.
