well guess what happened to me recently, I welded the nozzle to the metal I was welding!
I thought it was a good idea as it gave a better view on the weld pool and just made it easier
to see what was going on. I was also under the impression that using the shroud as support
was not the best thing to do, kind of like having a bad habit.... Correct me if this assumption is incorrect...
As for the flux core burning though, I do not honestly know but would assume this would have to do with too much power, again someone with more knowledge would be better able to answer you Mikes.
I personally find that with the amount of smoke produced with flux core it is generally easier
to weld without the shroud, each to their own. I am quite careful not to weld the nozzle to the work piece and have only done this once. Looks like the first bit of help I tried to give back to the community was incorrect!!
If it works for you!
Smart job there Gerry, and nice looking welds.
you do get some slag which practically peels off itself, so thats not a problem.
Thanks, No i'm using a Hobart 400amp setBest looking welds I've seen with flux core, Gerry.
Those are professional flux core shrouds, are they?
I'll guess you're not using a Clarke EN to get that sort of standard...![]()
This type of Flux core is totally different from the gasless flux core for a clarke EN, For starters you use a gas for sheilding, which in this case is simply Argosheild Heavy, and you have the set turned up fairly hot (Makes a lot of Fumes, so ventilation, Important)
Thanks Paul, They say flux core welding is like Stick but with a migyou do get some slag which practically peels off itself, so thats not a problem.
You can get some really good looking and smooth welds, and its not that hard to do to be honest. Some people push, some pull, I prefer pulling as then you can gauge roughly how much weld your laying and also it prevents the shroud making contact with the weld.
Generally when people ask me how i manage to get my welds that smooth i tell them i lick my finger and run it down![]()
Gerry please correct me as I am probably wrong but those welds look like spray transfer rather than short circuit....or is that just the nature of flux cored mig....? never had a chance to use it before.
Sean.
