Hi fellas. What would you recommend for a 1 cm long (maybe 2mm wide) scratch with some surface rust?
I know this seems very minor and to some people, is not even a problem to begin with, but i'm quite the OCD-er
and the rest of the car is really mint so i would like to deal with that as best as i can.
After some reading, the following seem to be the way:
sand or rust coverter/killer
prime with epoxy primer
paint
what do you think the best approach to dealing with it?
I'm thinking - sand off rust (it looks like it's just the surface), prime and paint?
Or would a rust converter/killer be more suitable in my case? The scratch is quite small and it's at an area that's hard to work on.
Heres the issue. There aren't many DIY products available in my country, so far i've sourced the following:
Dinitrol RC900
Dinitrol Zinc Spray (Very old can, i believe it's well over its shelf life!)
Sikkens 1K spot primer http://www.sikkenscr.com/sikkenscr/u...eraerosol.aspx
Some Spies Hecker 2K epoxy primer that my regular bodyshop spared me (needs to be mixed 1:1) Don't know which one exactly, but i'll check back with him. I'll need to apply this with a small brush.
It is on the inside of the chassis sill, so it doesn't have to be a 'perfect' repair, but i'd like do it as neatly as possible.
Thanks for any advice.
and the rest of the car is really mint so i would like to deal with that as best as i can.After some reading, the following seem to be the way:
paint
Dinitrol RC900
DW member here as well.
