diyhandyman
Hi, i have 2 compressors, a 90ltr 3hp 14CFM, 9cfm FAD i'd say belt driven compressor, and a 1.5HP 50ltr compressor, probably 4.5CFM FAD. I got the two hooked together with 5mtrs of hose, it has 1/4" nuts on the end but the inner diameter is probably less than that. I use a recoil 50ft hose with 1/4" nuts, the yellow Clarke one from machine mart, which again probably has a tiny inner diameter.
The two compressors work pretty well together, i know it's kind of useless to have the 1.5HP one but it's better than nothing and it gives me an extra 50ltrs.
I want to operate spray guns from the system, and my problem is that the 50ft hose acts as a reservoir, and the volume of air that initially comes out the gun is a lot higher than a second or two later. I'm assuming that a bigger bore hose will solve this.
I want a 3/8" system, for 50ft of hose or so, (ideally would like 100ft but i don't think that it would work very well) and the problem is that the compressors have 1/4" outlets, and not 3/8". Would this significantly bottleneck my system? i just want a constant flow of air coming out my system of as much CFM as possible.
At the moment i have the 3hp compressor with the 1/4" 5m sealey hose going from the pressure switch of the compressor to the pressure switch of the 50ltr compressor. On the pressure switch of the 50ltr, i have a regulator which has a 1/4" outlet, with the 50ft recoil 1/4" hose to the spray gun. So my question is that can i just replace the 1/4" (outer diameter i guess) hoses with 3/8 inner diameter hoses and i will have constant flow coming out the 50ft 3/8" hose from the 50ltr compressor to my gun? Or do i have to have 3/8" fittings all the way, which would be a problem because the 3hp compressor has a 1/4" going to the pressure switch, welded on to the tank.
Thanks for reading, and any suggestions are very much appreciated.
verry true but why does everything come in a pair when theres only one
