how do you go about welding thick metal say 2/3mm to 1mm sheet with out blowing holes through the sheet, thanks for help
i dont wana sound thick but say your overlap welding 1mm sheet to 1mm sheet, like a car floor etc, does that make you weld a 2mm weld, or are you still welding a 1mm weld, as my chassis is 2mm thick and im plating it up with 2mm plates were it needs it, if it makes it 4mm weld im screwed as welders only going to about 3mm,
