Quick question(s)...
I have a large item, its a 5m long cylinder frame which rotates, with approx 200mm to 250mm (length) butt welds, fixing a gusset plate (6mm) to a large ring (diameter 3000mm). The gusset plates are to strengthen a RHS cross member to either large end ring. There is nothing wrong with the welds themselves, but i wondered wether it is standard practice to leave a butt weld with a slight crater? It looks like most welds on the rings are done in spray transfer, where im pretty sure the rest of the fabrication is in dip transfer.
I feel that the crater/undercut is causing very slight cracking at a 30 degree angle (or so) to the weld.
I know from my own experience, any undercut of a weld is an area where a crack will propogate, but surely this large frame should be made to a standard that it will not crack up under load? Or is it a case these days where things are no longer made to last as long as they used to?
I am yet to contact the manufacturer, as i dont want to disrespect their workmanship, but i also dont want any issues with the frame. (which are prone to cracking with significant use/abuse!)
HELP!!!!!
Cheers,
stew
P.S Ill try get some pics up tomorrow.
HELP!!!!!
Cheers,
stew
