daveypower
ok so i set up the welder Sealey Supermig 150/5 as my first trail, ive done a pervious evening welding course in MIG, T joints, vertical advanced joint etc.
Anyways i couldn't get much of a weld but I am not surprized to be honest, Im using flux cored wire with out changing the polarity. as i cant change the polarity unless i open up the machine. I have no Gas at the moment.
First question is the wire i have says its flux cored wire to be used on straight polarity?? is this normal??
Second question is im clamping the earth to an old subframe which still has the black paint on it, Is this ok?? or should i grind a nice clean patch on it??
Third question is can i only weld to what the earth is clamped to? i Tried to weld some clean metal on concrete a few feet away from the earth on the subframe but nothing happend just wire coming out. I started welding then on the Subframe and i got an arc.
Forth question is there is alot of white smoke that went on to the shroud and the metal when i was trying to weld, But this could be related to question 1.
Fifth question, i had the welder turned up to 5 it goes up to 6, but i was afraid to turn it up to 6 unless i would blow a fuse because its on a 13amp plug.
Thanks for anyhelp.
Thanks for anyhelp.
