bigbadbugga
There were plug leads on the inside face of the head so it was a fuel engine.Amazing workmanship, didn't see any ignition gear though. Guess he was running it off compressed air?
Can't see them, also no wires going to the engine, no dizzy, no coolant.
I am referring to the engine in the OP, not the one BS refers to, BTW.
They showed the machining of the cams but its hard to tell whether he has done it as a dummy to just drive the inlet and exhaust valves or if he has set it up for the full suck squeeze bang blow cycle
it must be for show as there was no facility for cam timing on the crank driven gears...what a master piece that little gem is
have you watched the video end to end as far as i can see there is only one engine being built
the first post and the third post are different engines
http://www.break.com/index/worlds-smallest-v12-engine-2232389
http://www.youtube.com/watch?v=NaZqDEJ2F0U&feature=related
The first looks like an air engine while the second has spark leads and a distrubutor
