Richardj1978
New Member
Hi all,
I'm currently looking at converting an fuel tank to take an internal electric pump, and allow me to run a previously carburettor car with fuel injection.
It should be easy enough to spot/plug weld a swirl pot inside the tank, but the area I know I'm gonig struggle with is welding in a recessed mounting point in the top of the tank to allow the pump and sender unit to be fitted.
I've done a fair bit of welding in the past but only with thick steel (3mm+), and at the moment only have access to a Clarke 151TE MIG welder to do this.
I'm worried about the thickness of the metal (being 1mm), and getting the welds fuel-tight.
Just wondering if anyone has advice on doing this, or whether I'd be mad to even bother trying this with a MIG, and should just find someone who can TIG it up for me.
Any advice would be gratefully received.
Thanks
Rich
PS forgot to add, the tank is brand new so no vapour issues.
Unfortunatley due to the age of the car, there are no replacement injection tanks out there.
Thanks
Rich
