Hi guys,
Quick pressure question, just got my compressor(airmaster 14/60) the other day and hooked it upto my spray gun(devilbiss GTI pro) to check it all out. So it all works, but one thing I noticed, to get the 2 bar that the gun needs at the gun the output pressure at rhe compessor regulator is at around 7 bar, should the pressure drop be that much?, i'm using a 10m hose 8mm diameter I think. Sorry if these are daft questions, first time i've ever used a compressor,
if I used a shorter hose would the pressure drop be less?
Or if I used a larger diameter hose would the pressure drop be less?
All fittings are 1/4", just concerned if I ever need more than 2 bar with the max working pressure of the compressor at 8 bar what I would need to do.
Thanks and again sorry for the daft questions.
John.
John.
more cfm and less velocity using a larger bore
