Hi again, have cut out the rust, repaired underneath and sprayed with rust paint, what I am needing is advice for the steps on the outer'
Do I use a Poly filler over the metal to fill the area of repair, have Picklexed the metal so no rusting, as you can see it is a large area and will need extensive filling, tried to get metal as close to original as I could, but still learning, any Poly filler? or do I use fibre filler first then a poly over the fibreglass?
Then when the filling is done, do I use a good Epoxy Primer over the repair three coats then onto single pack paint, don't have the gear to do it in 2pk, what brand Epoxy primer, am in Australia.
Can get to the back of repairs so easy enough to Seal along all welds, then paint over the seams.
Any help will be appreciated, help in the past has got me to where I am now, may not be very good at repairs, but the vehicle would have ended up at the wreckers.
Cheers
AFter and before pics
Waz
Cheers
Waz
, luckily I have patience.
, will do some research on it as I have never heard of it, Keep up the good work on advising beginners and seekers of help.
