Hi all,
Now, before I start I'd just like to say that I know just enough about electrics to make me dangerous
, but I'm looking to put up some 500w halogen security lights with PIR sensors. I'm going to put up 3 units, 1 of them will be about 4 meters from the box, and the other 2 will be about 30 meters away. The cable will be run inside the building mostly clipped to the wall as it's an old farmyard type building, and also on the outside walls up to the lights. I think I can handle it, if I can't then I'll just run all the cables etc. and have a spark connect them into the box.
Got a couple of questions;
What size breaker (RCD?) do I need?
Will it make a difference if I mount them higher than the recommended 2.5 meters, as Idealy I want them at about 3meters?
What size/type of cable would be best?
Cheers!
, but I'm looking to put up some 500w halogen security lights with PIR sensors. I'm going to put up 3 units, 1 of them will be about 4 meters from the box, and the other 2 will be about 30 meters away. The cable will be run inside the building mostly clipped to the wall as it's an old farmyard type building, and also on the outside walls up to the lights. I think I can handle it, if I can't then I'll just run all the cables etc. and have a spark connect them into the box.Got a couple of questions;
Cheers!
, picks up any bodily movements within 20' rad & on goes light
