Hi guys, I'm looking to get the place nice and toasty before the weather hits.
I've not got much builderingy type experience, but I need to do 2 things. Fix the gutters & insulate the walls.
The gutters are cast concrete jobbers and leak at every joint (about every 15 feet). Some roofing monkeys tried half-heartedly to seal the gaps between the sections last year, but they still leak. What is the best way to seal them?
I need to add drainage to stop water sitting in the gutters - planning on just drilling a bunch of holes in the gutters!
Once that's done, I'm going to line the building. 2" expanded polystyrene seems cheapest, with plasterboard on top (nice and fireproof). Should I run 2" battens from floor to ceiling every 4 foot and just stick the insulation in between? I need to screw the plasterboard to the battens - how do I arrange them if the 4' insulation fits between the battens and the 4' plasterboard is supposed to sit on top of them - I see a discrepancy ahead!
Is that the cheapest way of doing it?
there will effectively be a gap behind the upper sections of insulation. How do I fit the polystyrene panels with nothing behind to push them against?
Ta for all ideas / help, Al.
