Just wonderin whether I should get another regulator. The one I have has a single gauge and I think the valve to regulate the flow might not be working correctly as You can unscrew it all the way off, which does not seem correct to me.
What should I expect to pay for a 2 gauge regulator ?
Thanks
Thanks. Although it says Argon will it be fine to use with Argon / CO2 mixtureI ordered this one on Friday. Just waiting for it to arrive.
http://www.ebay.co.uk/itm/Argon-Gas...523?pt=LH_DefaultDomain_3&hash=item23138f866b
flanjad,
I can remember doing the maths in my head and thinking 'hey this thing is a bomb'
wont do that again
You'll be allright, observe the correct procedures, and providing you look after the regulators etc, you cant go far wrong.
Having studied Chemistry that is exactly what I was thinking too. I also read in a welding book, that if a cylinder explodes and you are nearby there will most likely be nothing to pickup when the emergency services arriveflanjad,
Hi Jim, I just ordered a new regulator and at the same time purchased a flow meter. The one I had did not have one, and I suspect it was using either too much or too little gas.And don't drop it on your toe.
Is it just me that does a grunting bear hug with a 300 bar cylinder trying to get it high enough to sit on the welder?
Usually I'm just a little low and the the thing hits the welder which rolls forward on its castors.......
Oh, and get a flow meter, I find the scariest thing is coming back to find an empty cylinder! Flow meters are another line of defence against using too much of the precious stuff.
Jim
Sorry for that thought.
Jim
Yes, it's fine.
Two big rules - don't test for/ stop leaks by using your finger directly, and don't knock the valve off with a sledgehammer.
