Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Here's my problem, it's a rayburn, had it for about three or four years now, very secondhand, when we bought it it was missing the 'chimney control box' ie the baffle and air moderator(?) and just below this corner was a piece of cast iron (broken) about half the size of a postcard from inside the 'flue'? system.
The long and short of this is that when you lit it, it would smoke until the chimney was hot enough and drawing properly. And for clarity it would smoke from around the top enamel cast horizontal whole top thing.
This morning it was duly dismantled, and either the chimney corner, rear right hand side has had an impact to it or rains come down the chimney and caused expanding rust to break a couple of castings. This being where the smoke from the firebox comes up across the top of the oven and then up the chimney.
So I need to weld it back together, it doesn't matter how stong it is really, it just to keep the smoke in, I can't just bodge it back together with gun gum or fire mastic due to how its broken, once tacked together it can be smothered in fire mastic to make it air tight, but how....
I've just re-read the tutorial on cast, I can give it lots of preheat, I've only got standard steel mig wire 0.8, or I've got an arc with loads of 6013's, and i've got oxy-acetaline so perhaps I could braze it with rods??? I have recuperated all the bits and as soon as I find my camera I'll post some photos, just the technique I'm wondering about?
Thanks people, Mat
Thanks people, Mat
