Has anyone tried CO2 for cooling with Gasless wire?
I have a suspicion it might provide some useful cooling of the weld pool to get slightly more penetration on the thinnest steel (0.7mm) without blow through. I can just see two panel edges in just a few places on the reverse, requires a quick grind and reweld the now thicker metal. It is an tiny fraction of a second between not quite continuous penetration, full penetration & blow through. Could be the trigger requires too much movement. This is with 0.76mm Innershield wire. A 1kg Sealey cylinder is cheap, should last >40min which is ages, £7-9 refill.
Then again two layers of 0.55mm copper work brilliantly, I just lack the right wide-throat clamps.
Not sure which is going to provide a better trick - the copper?
This is outside, driveway is raised, on a hill, right by a T-junction in line with the prevailing wind. So gas wire is out even with a shield, tried, no chance.
.....even used the gazebo before
...never used flux core , and only ever used co2 at home ,managed so far
