Hi,
I am in the process of researching what is involved in building my own 8' * 4' cnc machine. I am currently looking at the frame design and wanted to avoid using aluminium profile.
I came across a chap who made his frame out of mild steel, but upon reading his article he has sort of said that welding is not suitable ?
He epoxy joined the key joints. I just wanted to ask any experienced members whether he is correct in what he says or whether it is over kill ?
The snippet below is from his web site. If you want to read the full blurb the link right at the bottom will take you to the web page.
Appreciate any comments you have.
"Welding is excellent when you want strength and simplicity in joining of awkward pieces together but it is not good enough for precise alignment since the weld shrinks and warps the steel even with thoughtful pre-stitch welding (and a few of us have stress relieving oven for steel handy or a precision grinder for later). Also, plain structural steel is not rolled perfectly square and flat, so plain bolted steel to steel joints are not workable because the contact area is only about 15-20% if you are lucky and torquing things tight together is very bad since it leaves the steel in strained condition and the structure will keep twisting and creeping and you will never align the machine. It may not be visible by a naked eye but in the 0.01" scales and smaller the movement is very noticeable, not to mention the fact that by bolting together unground steel will NOT make an accurate machine."
http://www.oneoceankayaks.com/madvac/machine_frame.htm
