Ratty
Putting the She in Sheds
Ok, at last..the promised pics (see this thread) of my little (big) copper washer/rivet project! I gave up on the idea of filling the little holes in the copper ballcock with rivets and soldered them instead.
One of the offending holes..
A pair of holes prepared for solder..
Soldered..
and patinated to blend in..
Then I had to make a large washer to reduce the hole which the fixing bolt came through, the bolt was temporarily held inside the ball with a short length of flattened copper pipe. In order that the steel bolt didn't contact the copper it has a rubber grommet fitted..
To make the washer, first I cut a piece of copper pipe;
Flattened it, screwed to a block (so I didn't slice any more of my fingers when drilling!).
The hole saw was used initially to mark the copper before drilling the centre hole;
then I replaced the hole saw to complete the cut;
Voila! One 55mm copper washer.
Soldered..
). I do know that if you hang a picture with a brass wire on a steel hook the electrolytic action between the metals will cause the brass to corrode and break...and something about sacrificial diodes in central heating tanks...my knowledge is hazy to say the least
. The thick rubber washer between the ballcock and the stand actually has a dual function as it means the ballcock sits tight and snug against the steel with no wobbles or distortion.
) and have just done the same for annode and got similar stuff (but only 387 hits) so my next search has to be wot's an annode and wot's a diode (cos I have absolutely no idea). Maybe tomorrow.
(google thinks there is) so took out an 'n' and got 271,000 hits. Bit of reading then
