for the price a bandsaw would be cheeper.........
tube cutter would be cheaper, mine cuts lovely and square and its adjustable
The tool above works quite well on smaller diameters but with leave the bore turned in slightly, so it will need dressing back with a file. The larger diameter and thinner the wall gets the less well they work, the wall of the tube distorts as it is being cut so the tool wonders off line. I have one for cutting very large diameter tube but it's hopeless unless the wall is at least 3 mm. This is a particular issue if the cut is being made near an open end instead of mid length.
For bends I use either my bandsaw or a mini-grinder. A 1mm blade on a 5" grinder gives a lovely cut. You couldn't cut bends with that vice-mounted guide for sure.
Only way to get perfect straight cuts is an orbital tube cutter, excellent kit, but expensive. Not a diy tool! Neat little video of how it works here
The jig, i have a very simple little jig in me tool box for cutting 48mm handrail tubes, its a bit of heavy wall 60mm pipe, little locking screw in it. One end is cut square other is at 45, just slip it over the tube, do the thumbscrew up, and scribe round it, or run the grinder round it.
Hmmm, yes they are expensive.
I want to put together a 2.5" stainless exhaust mid-section (x2, on my v8 motor). So I want to cut pre-bought bends and weld them together.
